So I bought a RTF X-250B a couple weeks ago. I only did about 6 flights with it total before a odd landing (no real damage) made a motor stop working. So I took it home, cleaned up the dirt around the motor and tried it again. It started running a little better, but then the ESC caught fire.
I've since learned that it was most likely caused by a collision with the prop and the ECS...but didn't think about it back then since I was mostly trying to keep my house from burning down. But in my attempt to troubleshoot the issue, I did what I normally do with computers when they aren't working - take them apart. So I took it all apart.
In testing the power control board afterwards, seems that power isn't getting to half the board now, so I assume the burning did a bit more damage then just to the ESC. Figuring I still have most of the components, and three good motors and ECS, why not learn how to build a quad and use this as a learning tool.
So I hooked up the battery connector to the power board using XT60 connector. Plugged a battery in, and checked with voltmeter. All 12 v connections were still good. So started easy and connected my video camera and transmitter. Powered it up, and checked to see if it was getting video feed - and it was. Did a little happy dance.
So then I figured I'd check the Flight Controller. Well since the 5v power from the board wasn't working, I figured I would use a working motor with a ESC to provide it. I got the Flight controller up and running, got the transmitter up and running, and the radio detects it and can arm it ok. Only issue is when I apply power, the one connected motor won't spin.
So being and engineer, I hooked up the Flight Controller to check flight and looked at what was going on. check flight shows that it does detect the FC nicely and can tell when it's moving. It sees the voltage from the VBAT. IT shows movement on the radio when I move things. So I went to the motors page and tried to activate the motor from the software - nothing moved. I unplugged everything and re-plugged, but same results. When the battery is plugged you can see the motor switch like it does when its booting up, so I suspect the ESC is ok.
Here's a video of this little project so far:
So at this point I'm trying to figure out the following:
1) Am I doing something wrong? What am I missing to get this one motor to work.
2) Is there a way to test the ECS and motor to see if they actually work, I have two more sets I could try if they don't.
3) What further steps can I take to troubleshoot this?
I see this as a learning opportunity from a drone I never really go to fly in acro. I have ordered a new frame and power control board to start building my first drone. I'm about to order motors and ECSs for it, but I'm hesitant since I don't know if there is something wrong with the FC or my building skills yet. So figured I'd reach out to you guys and ask for help.
The frame I ordered and PCB is this:
Amazon.com: Readytosky ZMR180 Carbon Fiber Frame Kit With 5V / 12V PCB for FPV Racing Drone Quadcopter gift: Toys & Games
I was thinking of ordering these motors and ESC:
Amazon.com: HOBBYMATE Quadcopter Kit Motor ESC Combo, 2 Pairs CW CCW 2204 2300KV Plus 4 PCS Upgrade BLHeli 15A ESC for For 180 210 250 RC Quadcopter Drone Multirotor: Toys & Games
figured the first drone build would be on the cheaper side and work my way up as I got better at building.
So any thoughts or directions of help?
