"no valid receiver signal detected"
Asi6
Im new to the fpv drone hobby I have a speedybee f7 v2 with a tbs crossfire nano rx. I have power to everything the transmitter and receiver bind but i dont get any inputs from my transmitter i have the uarts serial rx on and in the receiver tab of the speedybee app i have it set to serial based receiver CRSF. everything ive seen says its all right but there clearly is something wrong since my inputs arent going through. please help
# version
# Betaflight / SPEEDYBEEF7V2 (SB72) 4.2.11 Nov 22 2021 / 15:01:41 (norev_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 B07
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 C11
resource SERIAL_RX 4 A01RO_XCLR 1 NONE
resource COMPASS_CS 1 NONE
resource PINIO 1 A15
resource PINIO 2 NONE
resource PINIO 3 NONE
resourONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1ETRY
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
00 0 115200
serial 3 1024 115200 5760DING
featurserial 4 0 115200 57600 0 115200
serial 5 0 115200 57600 0 115200
# led
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0lor 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 200 900 0 0
# adjrange
adjrange 0 0 0 900 900 0 0 0 0
adjrange 1 0 0 900 900 0 0 0 0
adjrange 2 0 0 900 900 0 0 0 channels 0
vtxtable powerlevels 0
vtxtable powervalues
vtxtable powerlabels
# vtx
vtx 0 0 0 0 0 900 900
vtx dyn_lpf_gyro_min_hz = 200
se0 0 900 900
vtx 3 0 = 500
set gyro_filter_debug_axis = ROLL
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set aUTO
set rc_smoothing_auto_smoothness = 10
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider et failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_switch_mode = STAGE1
set failsafe_throttle_lo 0
set beeper_dshot_beacon_tone = 1
set yaw_motors_reversed = OFF
set crashflip_motor_percent = 0
set crashflip_ex_rescue_throttle_i =band_low = 1406
set 3d_deadba = 50
set gps_rescue_velocity_p = 80
set gps_rescue_velocity_i = 20
set gps_rescue_velocity_d = 15
set gps_rescue_k_mah_as_heading_divisor = 0
set telemetry_disabled_voltage = OFF
set telemetry_disabled_current = OFF
set telemetrrn_arming_disable = ON
set osd_warn_batt_not_full = ON
set osd_warn_batt_warning = ON
set osd_warn_batt_critical =im_2_pos = 234
set osd_remaining_time_estimate_pos = 234
set osd_flymode_pos = 234
set osd_anti_gravity_pos = 234
234
set osorce_pos = 234
set osd_throttle_pos = ate_time_pos = 234
set osd_adjustment_range_pos = 234
set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
setat_min_rssi_dbm = OFF
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_0
set displayport_max7456_wht = 2
set esc_sensor_halfduplex = OFF
set esc_sensor_current_offset = 0
set led_invers mco2_on_pc9 = OFF
set timezone_offset_minutes = 0
set gyro_rpm_notch_harmonics = 3
set gyro_rpm_notch_q = 500
se cgyro_rpm_notch_min = 100
set dterm_rpm_notch_haold = 350
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
seaw_relax = 200
set d_min_roll = 23
set d_min_pitch = 25
set d_min_yaw = 0
set d_min_boost_gain = 37
set d_min_advalimit = 1998
set yaw_rate_limit = 1998
# end the command batch
batch end
# _control_mode = NORMAL
set launch_trigger_allow_reset = ON
set launch_trigger_throttle_percent = 20
set launch_angle_limit = 0
set launch_control_gain = 40
set ff_interpolate_sp = AVERAGED_2
set ff_spike_limit = 60
set ff_max_rate_limit = 100
set ff_smooth_factor = 37
set ff_boost = 15
set idle_min_rpm = 0
set idle_adjustment_speed = 50
set idle_p = 50
set idle_pid_limit = 200
set idle_max_increase = 150
set level_race_mode = OFF
rateprofile 0
# rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 100
set pitch_rc_rate = 100
set yaw_rc_rate = 100
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_breakpoint = 1350
set tpa_mode = D
set throttle_limit_type = OFF
set throttle_limit_percent = 100
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
setimit = 1998
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
set ff_boost = 15
set idle_p = 50
rateprofile 0
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
Heres the dump
The lack of response between the radio & the receiver cannot be a BF issue. If you have confirmed the binding process then it is most likely the UART leads are reversed. Swap the R & T wires
Same On SpeedybeeF7V3 with a taranis 9XDlite. I solved the problem disconnecting first the VTX DJIO3, and disconnect the 2 lasts cables (RC) pins ( DJI remote control cables ) . then i connect the Receiver and the VTX with the only 4cables (5V/GND/TX/RX and not the others) and it works . ( from the Manual speedy bee F7V3 ;Some ELRS receivers got some sbus troubles ) . keep in touch
Bcgfam
