5" FPV Drone keeps falling out of the sky
noahmalin
Hey guys,
So, I had a crash a couple of months ago and broke one of my arms. Now, I've waited for two months to finally get the replacement arm and fixed it. But now, when I tried to test fly it, the quad keeps falling out of the sky for no reason. The distance is always different, sometimes 100 m and sometimes very close (in the video its about 5 m). I didn't change any settings in Betaflight, and this quad was flying fine for two years with my settings. The motors don't get hot, and I don't see any physical damage to the drone. Nothing is touching the props. I have the blackbox file attached with my latest test flight dvr video.
Just after the quad disarms, you can see that rxSignalReceived and rxFlightChannelsValid are still 1 and that failsafePhase is still 0. So, the flight controller itself isn't seeing a failsafe condition. It looks like it just disarms for some reason.
Does anyone know what could cause this? Thanks!
https://drive.google.com/drive/folders/1...sp=sharing
5 Inch X Hover Blastr V2
T-Motor F7 Stack - F7 FC, F55A PRO II 3-6S 4-in-1 ESC Combo
DJI Airunit
TBS Crossfire Nano RX, with immortal T antenna
Tango 2
4 x XNOVA 2207 FREESTYLE SMOOTH LINE MOTORS 1700 kv
Tattu R-Line batteries 6s 1800 mAh and 1400 mAh
# version
# Betaflight / STM32F7X2 (S7X2) 4.3.0 Jan 25 2022 / 12:40:47 (2e4f1c922) MSP API: 1.44
# config: manufacturer_id: TMTR, board_name: TMOTORF7, version: c2b8c0d3, date: 2021-06-18T03:42:42Z
# start the command batch
batch start
board_name TMOTORF7
manufacturer_id TMTR
# name: LINK QUALITY
# feature
feature -RX_PARALLEL_PWM
feature RX_SERIAL
feature GPS
feature TELEMETRY
# serial
serial 1 1 115200 57600 0 115200
serial 3 2 115200 57600 0 115200
serial 4 64 115200 57600 0 115200
# beeper
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -ARMED
# beacon
beacon RX_LOST
beacon RX_SET
# aux
aux 0 0 0 1700 2100 0 0
aux 1 1 2 1300 1700 0 0
aux 2 2 2 1700 2100 0 0
aux 3 46 3 1700 2100 0 0
aux 4 13 1 1700 2100 0 0
aux 5 35 1 1300 1700 0 0
# master
set acc_calibration = 50,53,86,1
set mag_hardware = NONE
set baro_hardware = NONE
set min_check = 1010
set max_check = 1990
set serialrx_provider = CRSF
set blackbox_sample_rate = 1/8
set blackbox_device = NONE
set dshot_bidir = ON
set motor_pwm_protocol = DSHOT600
set failsafe_procedure = GPS-RESCUE
set yaw_motors_reversed = ON
set small_angle = 180
set gps_provider = UBLOX
set gps_ublox_use_galileo = ON
set gps_set_home_point_once = ON
set gps_rescue_initial_alt = 88
set gps_rescue_descent_dist = 88
set gps_rescue_sanity_checks = RESCUE_SANITY_FS_ONLY
set gps_rescue_min_sats = 6
set gps_rescue_min_dth = 50
set gps_rescue_allow_arming_without_fix = ON
set osd_warn_batt_not_full = OFF
set osd_warn_core_temp = OFF
set osd_warn_rc_smoothing = OFF
set osd_warn_launch_control = OFF
set osd_warn_link_quality = ON
set osd_vbat_pos = 497
set osd_rssi_pos = 417
set osd_link_quality_pos = 2476
set osd_rssi_dbm_pos = 434
set osd_flymode_pos = 2401
set osd_current_pos = 128
set osd_mah_drawn_pos = 2534
set osd_craft_name_pos = 2465
set osd_display_name_pos = 395
set osd_gps_speed_pos = 2057
set osd_gps_lon_pos = 2080
set osd_gps_lat_pos = 2048
set osd_gps_sats_pos = 2433
set osd_home_dir_pos = 2061
set osd_home_dist_pos = 2062
set osd_altitude_pos = 2064
set osd_warnings_pos = 2377
set osd_avg_cell_voltage_pos = 2537
set osd_battery_usage_pos = 490
set debug_mode = GYRO_SCALED
set name = LINK QUALITY
set display_name = Noah Malin
profile 0
# profile 0
set vbat_sag_compensation = 40
set iterm_relax_cutoff = 10
set yaw_lowpass_hz = 70
set throttle_boost_cutoff = 10
set p_pitch = 64
set d_pitch = 54
set p_roll = 59
set d_roll = 50
set p_yaw = 63
set d_min_roll = 0
set d_min_pitch = 0
set feedforward_transition = 40
rateprofile 0
# rateprofile 0
set roll_rc_rate = 15
set pitch_rc_rate = 15
set yaw_rc_rate = 15
set roll_srate = 65
set pitch_srate = 65
set yaw_srate = 65
# end the command batch
batch end
Hey guys!
So, I finally found the solution. The arming switch was twitching; when I opened the modes tab in Betaflight and armed the quad, it was twitching on and off. So, I flashed the FC, and that solved the problem. Hope this helps someone with a similar problem.
Reactions: okw
muhendizs
