Omnibus f4 pro gps
Firstly, you'll be using iNav for GPS function, as Betaflight is not really designed for GPS. Don't worry, it's a fork off of Cleanflight so quite similar to what you're used to using. But like any new software there is a fairly large learning curve. Here's a link to the iNav wiki and if you click on the GPS & Compass Setup under Sensors Setup & Calibration in the right-hand column, it'll explain what you need and how to connect it and set it up. The good news is that it won't cost you much to get GPS set up as all you need is a GPS module. I really like the Holybro Ublox Neo-M8N module. Read up!
iNavFlight/inav
IolaLuther
