M3talrocksFPV
- Joined
- Feb 22, 2018
- Messages
- 298
- Reaction score
- 193
- Age
- 35
- Location
- Las Vegas
- Website
- www.youtube.com
Well the minimum IS 3.5 a cell (4 cells × 3.5v giving a minimum charge of 14v) the max is 4.2 (4×4.2= 16.8v), the mah is how fast it discharges, for instance 1500 mah means it'll pump out 1500 milliamps in one hour, the c is "current". This means how much can it pump out at once (burst) without significantly lowering the voltage. If you push your throttle up all the way really quickly it could drain the battery to nearly dead. You'll notice that when you hear your alarm it may just be a beep or two then go silent if you're not pushing your kwad. But when you try to give it input it starts to beep again.What do I set my minimum cell voltage to as well as max cell voltage and the warning I have for 3.5 also what's the capacity (mah) portion mean?
