PIDs for a 3"
Wrecked
Denmark
Hi all
I have a 3" (not a cinewhoop) and I dont think it flies as good as it should, so I suspect the PIDs.
I upgraded to BF 4.1 and run rpm filters, (other filters on minimum, slider almost all the way to the right) but Im still having vibrations even when going straight. I tried to lower the P and D a bit but not sure it helped.
Are you guys running standard PIDs on your micros? And do you think I should try to lower or raise my PIDs?
TIA
Reactions: fpv guy
Im going to anwser myself on this one in case it will help others!
I spend days trying everything regarding filters and PIDS, and the only thing that helped, was to downgrade to betaflight 4.0 without rpm filtering. Dont know why but I guess BF4.1 isn't very microfriendly.
i tried to update my 5 inch from 3.5 to 4.1 and quickly went back to 3.5
i think they are getting too fancy for people that just want to fly
i mean if i was racing or doing camera work i see why they have it so in depth but...
im waiting on my 3 inch to show up in the mail. ill prolly stick with an earlier version of bf when i set up
Reactions: Wrecked
