Questions about Wire Gauges and Servos
tj272004
I have a power module that has an end that needs to go to the ESC. However, the wire gauge is really small so the wire is huge and it can't fit well onto the + and - terminals so would it be fine if I soldered like a inch of 14 AWG wire to the larger wires and then soldered the 14 AWG wire to the pads so it would fit more comfortably? And I am trying to control two servos as one so would it be okay if I made a Y- cable for the signal cables so the two signal cables would operate as one and then for the power supply have them on separate ports that each give 5V. Would it function as one servo?
Thanks in advance!
Donrabeja
