Radio wiring not working on Dodo FC
spiderpig
So I like the Dodo FC and have it in several builds of mine. Recently I updated my 210 quad with 2204 motors and wanted to test it afterwards, but it didn't receive any radio inputs. I tested the radio receiver on another quad and it worked fine. So figured my wiring might have gotten screwed up somehow. I unsoldered the connections and desoldered it....still no radio inputs being seen in clear flight.
So I had an extra receiver to test with. Plugged it into a good quad that uses dodo Fc, bound it, and things worked fine. Moved it to my 210 quad and no inputs. So I re-flashed the dodo on the 210 quad and started again. I made sure radio uses PPM but still no radio inputs. The radio receiver is getting power since I can see the light is on. And it blinks when radio is off and solid when radio is on...so I know it's talking to radio ok.
Everything else works fine on the FC, motors spin up fine and it does everything else nicely. Any idea how to fix this?
IolaLuther
