Request For Advice
Andy Shutt
Hello,
I own a DJI FPV with goggles and an AVATA 2 with goggles, I am looking for another drone where I can use the controllers and the goggles that I already have.
Could you please suggest a next stage drone from you range that would work with the equipment I already have.
I am looking to fly something other than DJI
Thank you
Andy
Only DJI products will work with DJI controllers & DJI goggles and not all of them are compatible either. You didn't say which goggles and which controller. The only way to fly other than DJI is to build or buy a BetaFlight or Inav quad with a DJI air unit of some kind on it. They are available in all sizes.
here is some info that may help. if you have the dji goggles 2 or integra then you can get any drone that has a dji air unit, aka caddx vista (wouldnt use this as a recording system, camera isnt the best), a dji o3 air unit or the latest and greatest a dji o4 air unit or air 4 unit pro. if you have the new goggles (goggles 3 etc.) then you can use the o3 and o4 air units. if you have the goggles V2 (the ones with 4 antennas) then you can use the original dji air unit and the o3 air unit.
if you would want to use your dji controller as a controller then the original black one works with the air unit, the FPV controller 2 works with all the og. air unit, the o3 unit and o4 unit. im not sure about the controller 3 but i think its the same as the goggles 3. when buying a drone with the intent to use the dji controller be sure to select the PNP version of the drone or else you may have to do some configuration.
good luck and keep us updated on your purchase.
