I got 2 new AIOs from gepRC and trying to do soldering. Surprisingly all GND pads in 10pads cannot be soldered, but others are fine well. Is that GND pad different from other pads in general, like requiring higher temperature soldering?? Red circle pad is already burned out because I tried to do soldering many time with higher temperature. My solder iron sets to temperature 340-360, which should be good enough heat. I have no ideas with GNDs.
