Soldering problem
Professor
What am I doing wrong? I solder with 400 degrees Celsius and I can't heat up the ESC pads enough to get proper soldering done... I can see how it looks in the pictures, it just doesn't melt? When I apply it directly to my soldering iron it melts but not on the ESC? What am I doing wrong??
What iron? Too low power and/or too small tip probably.
used the sq-001 with the smallest tip... doesnt matter tho since i ruined my esc now :(( pretty stupid
Based on the CF-10A data sheet, soldering temp: 270-350C. Keep solder tip clean. Tinned iron tip before use. I suggest you experiment or practice on the damaged board before trying again. I also use a liquid flux on the pads even though the solder has flux built in. Soldering time is 1-3 secs. Abort if you feel it's taking longer. Better to try again then to overheat the board.
thank you! I do use a noclean flux pen and apply it on every pad before soldering
also good idea to use the damaged board for practice thanks almost threw it away already...
in the end i do think its because of my power supply, being a cheap led cable which is capable of 12v which is the least amount of volts i have to use for the solder iron and it does tell me its 11,62v or something so that might be it
also when i managed to melt it, it took about a whole minute and the board got hot like ****
cost me 80€ to find out what i did wrong🤦‍♂️
I bought new core now because i dont have much left and it is a bit different saying 50g NIWT
What is NIWT? lol
also i bought a power cable with 2,73A / 24V / 65W which should work better
Looks like NIWT 50g refers to the weight or amount of solder. Here's a photo of my soldering station. You can find them on the webs for around $70. I use 110v. My unit has interchangeable tips and a hot air gun. I use the hot air for shrink tubing.
For heavy connections you want to use the biggest tip you can, and give enough power to the soldering iron. For that TS100 rebrand you'd want at least a fully charged 4S, <12V isn't going to cut it.
If you are going to build more than one drone you should invest in a quality soldering station. I have a HAKKO FX-888D. Might be a bit of overkill but works nicely. And you can buy one for about the price of the board you just fried.
I would probably try a medium chisel tip first. To make a good join all of the solder has to be flowing at once.
His iron is just as capable, no need to buy another one. Just use the appropriate tip and supply voltage high enough for it to perform properly.
erix fpv
