Hey everyone,
I'm an undergrad student studying engineering, finally building my first racing drone, and have run into a bizarre issue:
When I connect my drone via USB to Betaflight, I can see the IMU output and everything works as expected. When I turn on my RC transmitter, again, everything works fine, and roll, pitch, yaw seem acceptable. If I turn off the RC and plug in the flight battery, everything is still fine. When I plug in the flight battery and turn on the RC transmitter, I can read the RC signals, but the IMU bugs, with strange drift in roll, pitch, and yaw. It doesn't seem like a typical mag interference problem as I have moved the FC away from high current wires and I have to conclude that it is caused by the combination of RC transmitter and flight battery.
Here are my drone's specs:
-Frame Anniversary Special Edition Martian 215 215mm Carbon Fiber RC Drone FPV Racing Frame Kit 136g
-Flight Controller Micro 20x20mm Betaflight Omnibus STM32F4 F4 Brushless Flight Controller Integrated with BEC OSD
-ESCs Racerstar RS20Ax4 20A 4 in 1 Blheli_S Opto ESC 2-4S Support Dshot150 Dshot300 for RC FPV Racing Drone
-Motors 4X Racerstar Racing Edition 2205 BR2205 2300KV 2-4S Brushless Motor Black For 210 X220 250 280 RC Drone
-Transmitter FlySky FSi6 (cheap one)
-Battery AHTECH Infinity 4S 14.8V 1500mAh 85C Graphene LiPo Battery XT60 Support 15C Boosting Charger
Has anyone heard of anything like this?
Thanks,
Spencer
Thanks,
Spencer
