two more issues...vtx and flysky fsi6
landonnap
Sorry for how many issues I have and how much I post but once again I've run into two problems. The first being I cannot get my transmitter to work with betaflight as in i get no readouts when I go to the receiver tab, I have tried both ibus and ppm setups but am very confused, I have my FlySky FSi6 reciever plugged into the ibus port as well as the betaflight configuration setup for ibus, I have tried changing the serial rx port in the ports tab with no luck. The second problem is I cant seem to get a video feed from my lumenier 200mw vtx to my eachine ev800d goggles, I press search and it pops up a black screen, I have tried changing the output of my vtx as well as pressing search many times. I would greatly appreciate any help, thanks!
When you lock on to a black screen it means the vTX is transmitting, but it has nothing to show. It is either a camera issue or a wiring issue.
Wire your vtx/cam together (without going through fc for osd) and see if it works that way, if so, it's either your fc or wiring/setup
Landonnap, what was your fix for your transmitter not showing up in BetaFlight?? I switched from PPM to IBUS on my Wizard like I have done on several other Wizards and now I lost my controller bars in BetaFlight.. I switched everything back and no luck.. The transmitter (controller) shows battery for RX and TX... Meaning it is reading power to both?? But nothing in controller section of BetaFlight..
ebchopra
