Entering CLI Mode, type 'exit' to return
# diff all
# version
# Betaflight / STM32F411 (S411) 4.2.8 Feb 15 2021 / 12:09:04 (101738d8e) MSP API: 1.43
# config: manufacturer_id: MTKS, board_name: MATEKF411RX, version: ee671311, date: 2019-10-16T11:49:37Z
# start the command batch
batch start
# reset configuration to default settings
defaults nosave
board_name MATEKF411RX
manufacturer_id MTKS
mcu_id 005000493539511534363532
signature
# name: TinyHawk II
# beeper
beeper -GYRO_CALIBRATED
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSE
beeper -RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_SET
# map
map TAER1234
# serial
serial 1 2048 115200 57600 0 115200
# aux
aux 0 0 0 1700 2100 0 0
aux 1 1 1 900 1300 0 0
aux 2 2 1 1300 1700 0 0
aux 3 13 2 1700 2100 0 0
aux 4 35 3 1700 2100 0 0
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable band 1 BOSCAM_A A CUSTOM 5865 5845 5825 5805 5785 5765 5745 5725
vtxtable band 2 BOSCAM_B B CUSTOM 5733 5752 5771 5790 5809 5828 5847 5866
vtxtable band 3 BOSCAM_E E CUSTOM 5705 5685 5665 0 5885 5905 0 0
vtxtable band 4 FATSHARK F CUSTOM 5740 5760 5780 5800 5820 5840 5860 5880
vtxtable band 5 RACEBAND R CUSTOM 5658 5695 5732 5769 5806 5843 5880 5917
vtxtable powerlevels 3
vtxtable powervalues 0 1 2
vtxtable powerlabels 25 100 200
# master
set acc_calibration = -30,-67,0,1
set mag_hardware = NONE
set baro_hardware = NONE
set min_check = 1010
set max_check = 1990
set rssi_offset = 20
set rx_spi_protocol = FRSKY_D
set motor_pwm_protocol = DSHOT600
set motor_poles = 12
set vbat_max_cell_voltage = 440
set vbat_min_cell_voltage = 320
set vbat_warning_cell_voltage = 330
set current_meter = NONE
set small_angle = 180
set deadband = 2
set pid_process_denom = 1
set osd_warn_batt_not_full = OFF
set osd_warn_visual_beeper = OFF
set osd_warn_core_temp = OFF
set osd_warn_rc_smoothing = OFF
set osd_warn_no_gps_rescue = OFF
set osd_warn_gps_rescue_disabled = OFF
set osd_warn_rssi = ON
set osd_cap_alarm = 450
set osd_vbat_pos = 2412
set osd_rssi_pos = 2138
set osd_tim_2_pos = 2423
set osd_flymode_pos = 2113
set osd_vtx_channel_pos = 2401
set osd_craft_name_pos = 2121
set osd_display_name_pos = 394
set osd_pid_roll_pos = 353
set osd_pid_pitch_pos = 34
set osd_pidrate_profile_pos = 186
set osd_warnings_pos = 2345
set osd_avg_cell_voltage_pos = 374
set osd_flip_arrow_pos = 310
set osd_rate_profile_name_pos = 23
set osd_pid_profile_name_pos = 2
set osd_stat_max_spd = OFF
set osd_stat_battery = ON
set osd_stat_max_curr = OFF
set osd_stat_used_mah = OFF
set osd_stat_bbox = OFF
set osd_stat_bb_no = OFF
set osd_stat_total_time = ON
set vtx_power = 2
set vtx_low_power_disarm = UNTIL_FIRST_ARM
set vtx_freq = 5806
set vcd_video_system = NTSC
set frsky_spi_tx_id = 204,51
set frsky_spi_offset = -18
set frsky_spi_bind_hop_data = 0,65,130,195,25,92,155,222,50,115,180,10,75,140,205,35,100,165,230,60,125,190,20,85,150,215,45,110,175,5,70,135,200,30,95,160,225,55,120,185,15,80,145,210,40,105,170,0,0,0
set gyro_1_align_yaw = 1800
set name = TinyHawk II
profile 0
# profile 0
set dyn_lpf_dterm_min_hz = 0
set dyn_lpf_dterm_max_hz = 250
set dterm_lowpass_hz = 100
set dterm_lowpass2_hz = 200
set feedforward_transition = 25
set acc_limit_yaw = 100
set crash_recovery = ON
set iterm_relax = RPY
set iterm_relax_type = GYRO
set iterm_relax_cutoff = 11
set iterm_windup = 40
set iterm_limit = 150
set throttle_boost = 4
set p_pitch = 105
set i_pitch = 125
set d_pitch = 95
set f_pitch = 100
set p_roll = 105
set i_roll = 125
set d_roll = 95
set f_roll = 100
set p_yaw = 95
set i_yaw = 95
set d_yaw = 45
set angle_level_strength = 60
set horizon_transition = 80
set level_limit = 30
set horizon_tilt_effect = 80
set horizon_tilt_expert_mode = ON
set d_min_roll = 0
set d_min_pitch = 0
set auto_profile_cell_count = 1
set launch_control_mode = PITCHONLY
profile 1
# profile 1
set iterm_rotation = ON
set p_pitch = 70
set d_pitch = 55
set f_pitch = 70
set p_roll = 70
set i_roll = 90
set d_roll = 55
set f_roll = 70
set p_yaw = 75
set d_yaw = 13
set f_yaw = 80
set horizon_level_strength = 30
set d_min_roll = 0
set d_min_pitch = 0
set auto_profile_cell_count = 2
profile 2
# restore original profile selection
profile 0
rateprofile 0
# rateprofile 0
set thr_expo = 50
set roll_rc_rate = 80
set pitch_rc_rate = 80
set yaw_rc_rate = 80
set roll_expo = 60
set pitch_expo = 60
set yaw_expo = 20
set roll_srate = 60
set pitch_srate = 60
set yaw_srate = 60
set tpa_rate = 25
set tpa_breakpoint = 1650
rateprofile 1
# rateprofile 1
set thr_mid = 20
set thr_expo = 50
set roll_expo = 60
set pitch_expo = 60
set yaw_expo = 20
set roll_srate = 60
set yaw_srate = 60
set tpa_rate = 45
set tpa_breakpoint = 1450
set throttle_limit_type = SCALE
set throttle_limit_percent = 75
rateprofile 2
# rateprofile 2
set thr_mid = 0
rateprofile 3
rateprofile 4
rateprofile 5
# restore original rateprofile selection
rateprofile 0
# save configuration
save
