so with my quad connected to betaflight I go to modes and set the values for my switches and notice there's no acro setting. Just air mode, horizon mode and angle mode???!!!! How do I get acro on there
I may have horizon and acro modes confused but if you fly around with the one that limits pitch and roll, you will likely do some un-intentional flips and/or rolls when first going to the other or acroUse the horizon spot for acro
What's a good sim. DRL??Bronco, if you are able to fly acro on the sim, you should be fine.
@devin120, Skitzo mode is Raceflight isn't it?
DRL is $20 thoughI used DRL cause it's free and i'm cheap...lol.
FPVFreerider has a free small one also, it's easier to use but very small
It wasn't when i downloaded it. It's not the one on steam, its this oneDRL is $20 though
Thanks man your input it very much appreciated and I will do exactly what ya said. Seems like a good formulaHey Broncosdad, just do like Wayne said. Rip through a few packs until you get used to how the sticks feel. I started off in angle mode, but quickly saw how limiting it was in controlling. After a while, the PID tunings in angle mode will seem to be fighting your stick controls. When you get better, just turn angle mode off on your FC, then stick with Acro mode all the way. Then increase your PID rates until they're at a level that feels right for you (but not too much or you will start to get oscillations). Stick to one quad for a while and learn it well, then think about your next quad challenge/ build.
