Whats the Capacitor for
Mattys74
I bought a iFlight SucceX Mini F4 V2 35A with VTX Flight Tower Stack, and it came with a Capacitor. I would like to know where do I put it and what is it for?
The capacitor helps to smooth out any voltage spikes (sort of stores a higher voltage peak during flying and releases it during periods of a reduction in voltage). I cooked a number of voltage regulators before fitting a capacitor, they are usually a low ESR to help with the filtering of the capacitor and mine are fitted across the battery voltage pads. Some folk fit them individually to their ESCs for probably a better filtering set up.
Need to remember to fit the +ve lead of the cap (usually the longer leg or marked on the cap body) to the +ve pad of your distribution board and the -ve lead to the -ve pad on the board.
Thank you for the help and yeah that's where I will going to connect them to the battery pads
IolaLuther
