- Joined
- May 18, 2021
- Messages
- 39
- Reaction score
- 26
- Age
- 44
face planted the drone while doing some low altitude back flips but that was enough to crack a front arm in 2 places
I chose the lazy (and more expensive) way to send it back to DJI for repair. Should have it back tomorrowA little bit of fiberglass (or carbon fiber) and epoxy and it will be as good as new.
So you had the arm bracers on and it still cracked?I chose the lazy (and more expensive) way to send it back to DJI for repair. Should have it back tomorrow
Yep but like Oneball said maybe the arm would have completely snapped off without the brace. Which would have still ended with the same repair cost lol. Anyway got it back from DJI and now I'll keep the more aggressive freestyle flying for the carbon fiber quad.So you had the arm bracers on and it still cracked?
Just curious, how much was the repair cost?Yep but like Oneball said maybe the arm would have completely snapped off without the brace. Which would have still ended with the same repair cost lol. Anyway got it back from DJI and now I'll keep the more aggressive freestyle flying for the carbon fiber quad.
87$ for repair. front arm module is only $7. set of props $14. Labor $65. Or you can ask for a complete drone replacement for $260 with DJI care refresh.Just curious, how much was the repair cost?
$87 isn't bad, what about shipping? Just wondering in case I need to send mine in some day.87$ for repair. front arm module is only $7. set of props $14. Labor $65. Or you can ask for a complete drone replacement for $260 with DJI care refresh.
Prepaid shipping from DJI. Overall process took 1.5 weeks$87 isn't bad, what about shipping? Just wondering in case I need to send mine in some day.
This is good information. I hope I understand correctly. It sounds like the broken arm replacement was a total of $87 and took 1 1/2 weeks to get it back, and that was without DJI Care? Is that right?Prepaid shipping from DJI. Overall process took 1.5 weeks
With DJI care refresh. Not sure if things are different without.This is good information. I hope I understand correctly. It sounds like the broken arm replacement was a total of $87 and took 1 1/2 weeks to get it back, and that was without DJI Care? Is that right?
Thanks. I misunderstood. Sounded too good to be true.With DJI care refresh. Not sure if things are different without.
