2" Flyno cerberis tuning question
Futuramille
Florida USA
www.youtube.com
Heres a good one... the 2" on 450mah flies 1.5min. motors are good temp but its snappy fast. do you think I could get more time with better tune?
also it forward flips forward faster than back flip and rolls left faster than right rolls. kinda strange as there is no such adjustment in betaflight. painfully slow one way and over done the other regarding rates.
Its beastly and I want to calm it down (brobably just add a bit of expo) on a switch? flight times are short though... batteries are pretty warm after a flight. absolutely impossible to fly indoors!!
thoughts?
cerberus 2"
HGLRC f420 stack
brother 1106 7100 kv
So no one has a clue or did I ask the question wrong?
were at Orlando speedway today.. saw Le Drib fly and got an autograph.
ball's out .. this is fun.
Reactions: ph2t
Have you tried a software reset and load defaults for your fc? I know it sucks, especially if you have a lot of config but it can help to blow it all away and load old trusted configuration by hand than import an old config file that may contain the cause of your Different rates when turning.
Hope you figure it out!
Reactions: Futuramille
I was considering that too. just reload the FC.. re sync the 4 in 1. only changes Ive done is drop D by 8 and set idle to 1080 to cool it down. that worked nicely
thanks for the advice sir!
