Gates N Gaps
Thanks Wayne. 450mah 45C, the flights aren't long... 1.5 min. I leave the screen blank and just set a timer switch on the TX. I have 6 batteries so its a fair session.
D is way low fighting motor heat so its kinda susceptible to prop wash shivers but it flies ok.
Thanks for confirming that Randy!
is there any real difference between 1105 6000kv and 1108 6000kv?
Not going to replace the 7100s any time soon as they are working fine after 33 batteries.. just validating for future reference.
Well, kv is kv, but the 1108's would be a bit heavier, and should have a bit more grunt, bit could also suck juice faster.
The Diatone R249 is running 1105's at 5500kv and is a 3s and 4s quad. I think 1108 could be a bit much, but i can't say for sure. One thing is for sure, they would be 1/3 taller that the 1105's.
Reactions: Futuramille
IolaLuther
