Acro Mode not Working right
M.A
Hello everyone,
I bought a used iFlight Titan Dc2 with the dji system. I flew with it first of all in Angle mode and everything was ok, later when I tried the acro mode it started good but after a minute when I try pitch forward it goes right, and when move it right it goes left. I reset the Flight controler and then copied the original Settings from iFlight and tried it again but it kept doing the wrong movements is acro mode. In angle mode everything was good. Shall I just try a new Flight Controller or could it be a problem in the programming?
Thanks for your help
I would confirm in the BF Receiver tab that the channel mapping is correct...i.e. EATR1234 or AETR1234, etc. although if it is not then Angle mode would no work right either, so...???
See that everything is moving correctly on the BF Setup tab as well and perhaps calibrate the Accelerometer, although it is not involved in Acro mode.
Soso
