I want to be able to use the DJI RE Goggles for my analog drones. The antenna plug for the DJI RE goggles is LHCP, but my Tinyhawk 2 drone is RHCP, along with most other micro quads from what I've read. I broke the VTX antenna on the Tinyhawk 2 and replaced it with a Lumineer circular antenna, but it is RHCP. I get a great image five feet away, but very poor range, worse than the linear antenna that came on the quad. I could buy and install an LHCP antenna, but I don't want to have to switch antennas on every analog quad I might buy. It would be cheaper and more convenient to convert the goggles to RHCP. I also have the DJI Digital FPV goggles and RC, but for just flying around the house and yard, it is cheaper to use analog and the quads are much lighter than having the DJI air unit or Caddx. I have searched quite a few SMA connector stores, such as Amazon, but what is needed is an adapter with an SMA male jack to screw into the SMA female plug that is on the goggles and the other side of the adapter needs to be an SMA female jack (not plug) that the SMA male plug on my antenna will screw into. So, what is needed is an SMA male jack to SMA female jack. Darned if I can find one anywhere. I already have an SMA adapter which has female plugs on both sides, so an SMA male jack to SMA male jack would also work, but I cannot find one of these either. Thanks for any links to adapters that will solve this issue.
