Air unit blackout
thetechnobear
Does anyone here have an experience of the DJI Air Unit doing a black out?
Ive flown countless flights with my current 5" drone, all perfectly ok... no video issues, even out to 1.5km.
usually, I turn back when bandwidth drops to < 10mbps
all good, but recently Ive had a couple of flights, where i suddently lose video, one second its 50mb, next screen freezes and is then black.
yesterday was particularly bad, I was at the top of the mountain, very remote... and suddenly black, (about 500m from me)
fortunately, I had gps rescue setup, so after a very long 15 seconds, the video returned, and I could fly home.
but really shook me up, since if this had not worked, it would have been lost for good!
today, I reviewed the footage from both googles and air unit,
and considering where I was sitting, whilst might have been partially obscured (los) , it looks far fetched that the signal was completely blocked.
the only thing that looks a bit suspicious (from a signal strenght perspective) is that it failsafed when the drone was at 90 deg to me, so mid turn.
this would obviously be the weakess orientation.
but as I said, goggle footage shows zero breakup, its just 50mb clear , then nothing!
googles then 'restart', when gps rescue has climbed, and is thinking about coming home - when I retake control
(interesting first few seconds of new google footage, show some video breakup)
so a bit concerning, im not 100% convinced about it being a lack of signal issue...
do you know anyway I can diagnose this? some logs?
are there any known issues?
Im wondering what I can try/test (in a safe way ;)) ?
thoughts?
notes:
- dji air unit, v2 googles, iflight crystal hd + omni, goggles running off 4s with 14.8+ v
- 1200mW output
- countless flights where this is ok, flights before and after had no issues.
- this was 1 min into second flight, air unit was 'unlocked' had not been sitting on ground, so should be 'cool'
- hot day (30+ C) but quite windy, and was high - so I dont think a temperature problem?
- only 1 min into flight, on 6s fully charged - I was not doing any acro, so current/power I cannot see being a problem
- googles i use with dji fpv, and never had an issue... so guess if an issues , it'll be on drone/air unit side.
CrocMonster
Malmö, Sweden
Did your goggle fan spinn up, goggle crashes and then reboots, new splashscreen like mine did (see post above)?
What goggle firmware are you on?
nuclearheli
