Arming Tinyhawk Freestyle 2
mrmund
I've got my Tinyhawk Freestyle 2 bound to my T8sg. I've got my switches set up for arm, beep and flight modes. With the aircraft connected to Betaflight I can see everything works including the arm switch(box turns red and says disabled, motors will spin from the motors tab).
Once disconnected from the computer I tried to start it up but it won't arm(props won't spin up).
The beeper works so it seems like it should go.
Any idea what I'm doing wrong?
Joshua Bardwell is a godsend, just watch these it could help.
If these are not the ones that helped his channel I guarantee you has it, just look around.
Reactions: BigAl07
It is likely either another Arming disable code, your throttle isn't going below the min arm value, or you are set for Motor Stop in BF config page where the ESC protocol is.
Reactions: BigAl07
powgoesthecow
