AVATA ( the first one ) with FPV Controller2
MARK (LI)
I have been trying to find a tutorial for using the AVATA with the FPV controller .......how to use the sticks and what reaction to expect from the drone....has anyone used one they could suggest?...or even heard of one?
You don't in those, if you want that you then use manual mode, which you'll probably want to train on a simulator first. Then go for it on the real thing with the default attitude limitation to get the feel, then remove that once comfortable.
Reactions: MARK (LI)
That's what I am trying to figure out...how to fly in Manual mode and do acrobatics
Throttle is really throttle instead of being a vertical speed command, other sticks are rotation speed around the aircraft's axes.
Again try it in a sim and you'll see.
TomasZaTo
