Bad FC? (solved)
rtkDarling
Hey guys, I could use some help. I think I have a bad FC. I have one signal wire that won't output. I've switched the wires around so I know all the ESCs and motors work. I've also made 2 harnesses now so I know it's not a wire or connector. No matter what I can only get three motors to spin. Bad FC?
Security Check Required
  • Sad
Glad you got it figured out! I've had to do this numerous times as the Radix FC has a habit of not outputting on S3 so I switch it to S5 pad.
****. I could've saved a couple of FC's and saved some money if I knew I could do that. I threw em away and just replaced the whole FC's.
WilliamDaugherty
