Betaflight receiver Tab no Feedback
FlyinMunki
Hi Folks,
I’m using a Flywoo Explr Lr4 with a Geprc ElrsRx and external elrs Tx module with it on my zorro. The light on the reciver seems solid the motors do work when run a test in beta flight only thing is, once I head-down to the receiver I get no feedback on the screen when the sticks are moved on my controller? A little help would be appreciated.
Check that your rx and tx are wired properly... I had the same problem the other day and double checked and had the receiver wired wrong.. What happens is youre supplying power but it's not working.. If it's not that its an option in betaflight you need to click.... Check your receiver wiring :)
Reactions: FlyinMunki
WilliamDaugherty
