Bind Button Broken; BetaFlight work around?
Kspearson1
Anyone have a workaround for a inoperable bind button? RXSR. Tried poking the area with a pin but doesn’t seem to work.
Reactions: RPR
Hi,
I have the same problem with a broken bind button on a Blade Scimitar 170. By a miracle, the LHS was able to solder a wire across the terminals. It goes into bind mode and binds but just stays there because obviously I have to remove the wire. Which do you think is right: bind it and leave it powered up then cut wire or bind it, remove power, then remove wire? Thanks
You can usually initiate the bind from Betaflight in the CLI. Depending on the version and firmware it will be bind, bind_rx, or similar. Use the help command to get the option for your version of the firmware.
Welp, just broke my bind button on my O3. Which terminals do I have to short to get this to bind once I open up the air unit?
davidfpv
