Bricked fc 2 of them
Davey
Nj
Hello again. So f3 fc I was checking settings to set up a nother and flashed firmware but in the middle realized the wrong copter so I understand plugged in the middle of flashing. Now I can't reflash or connect to bf. I think it won't release bootloader because only the blue lite lites when connect any time no red flash. Opens bootloader but no flash. Note I flashed another f3 fc no prob. . Any thoughts
FC's are read-only so you can't brick them. Try going into bootload mode (short boot pins or push-button, depending on board), then plugging in USB cable. The red light will only flash when data is processing. It will flash fast when writing in firmware into the flashchip. Then after writing firmware, wait til the red light blinks slower, then you know firmware took properly.
Donrabeja
