Can you guys take a look at my parts list for my first drone?
connor mccann
So to keep me busy whilst I research for parts I've ordered a h8 mini drone to practice with.
I'm hoping to automate my drone and control it with my laptop, I'd like to focus on thrust and stability for moving objects safely, mainly for indoor use.
Here are my parts so far :)
Frame - 110mm 13g £9.26 Alfa Genie110 110mm FPV Racing Frame Freestyle Stretch X Frame Kit For RC Drone
Propellor - 2435 Nylon 4 Blade 1.1g 2.4inch £1.79 ebay 2Pairs 2435 PC Nylon 4Blade CW CCW Propeller 2.4 Inch Props for Micro FPV Drone | eBay
Motor - 1107 4000KV Brushless 8.02g £11.42*4 Hawksky AT1107 1107 4000KV 5500KV 6500KV 7500KV 8500KV 10000KV 2-3S Motor for RC FPV Racing Drone
Flight Conroller - Realacc_Super_SF7 20*20 5g £23.36 Realacc 20X20mm Super_S F7 Flight Controller Betaflight STM32F745VGT6 2-4S BEC 5V1A 20X20mm for RC Drone
Power distribution board -150A £5.00 Furious FPV Power Distribution Board for Piko BLX Flight Controller
camera - ?
reciever - 10g £4.84 Original JJRC H31 Receiver Board RC Quadcopter Spare Part - $6.01 Free Shipping|GearBest.com
battery - 2s 7.4v 550mAh 70C 30g £4,38 ZOP Power 7.4V 550mAh 70C 2S Lipo Battery JST Plug For Aurora 90 100
ESC speed controller - 20A 4.9g 4in1 £19.14 20x20mm Spcmaker SPC 20A BLheli_S 2-4S 4 In 1 Brushless ESC Support Dshot for RC FPV Racing Drone
VTX Wireless Video Transmitter - 6-18V 5.8Ghz 1-600mW £26.33 ImmersionRC Tramp HV 6-18V 5.8GHz 1mW to>600mW Video Transmitter International Version V2
Welcome to the forum . Sure someone will be along shortly that can help you .
Hey @HighTechPauper I sent this guy over from Mavic bragging on you guys isn't it anyone you know or you can tell him to help him to keep from making me out a lair ?
Reactions: Futuramille
welcome, check out hglrc f420 20x20 stack. my micro is a bit bigger @119mm and motors are 1101 7100s. I also recommend the runcam eagle micro cam and matching runcam vtx.
so I'm recommending you use a pdb and FC made for each other to add simplicity. same with vtx and camera.
there's alot less hassles this way. makes a cleaner build and experience.
hopefully someone with that frame will chime in here as well regarding additional motor info.
Again, welcome...
.. and Donnie, this is the right spot for support and cheering on the addiction.
FC/PDB combo
HGLRC F420 F4M3 FC OSD / 20A BLHeli_S 2-4S 4in1 ESC - No VTXDefault Title
camera
RunCam Micro Eagle
.... matching vtx, you can mount it to the stack or put it on the back side of the camera to shorten the stack.
RunCam TX200U
Im NOT saying you're list of goodies wont work. its just a recommendation on 20 x 20 stacks.
This is arguably "best available" NOT most cost efficient!! I find using best available when you build quads... makes fun last longer. 1) better equipment longevity 2) most important for me.. no envy of better gear coming out for a longer period of time. When you know you put the best available in, you can't question the gear. Making your thumbs the only true variable between good and bad flights.
If you cant blame the gear due to questions on quality you realize its all you, stop questioning gear and just fly it.
Eleveniseven
