Cannot Setup Bidirectional DSHOT on my iFlight SucceX-D Mini F7 TwinG Stack (Mini F7+40A ESC)
SpeedBump
Hi Everyone,
I’m trying to use Bidirectional DSHOT, and all my motors are reporting 100% rpm errors in the motor tab.
I’ve built a 3” using the IFlight SucceX-D Mini F7 TwinG Stack (Mini F7+40A ESC). I’ve updated the ESC TO BLHeli 32.8. I’m using BetaFlight 4.2.8.
The ESC Specs are as follows
ESC // SucceX 40A
* MCU: STM32F051K66
* Up tp 48kHz PWM frequency
* Capacity: 470uF/50V
* Current Sensor: Yes
* Input: recommended 2-6S
* Constant: 40A / Burst: 50A
* BlHeli32 telemetry: Yes
* Supports up to Dshot1200, Proshot, Oneshot, Multishot
* Target: iFlight-BL32-4IN1
* Weight: 7.2g
* Mounting pattern: 20*20mm φ3mm with Grommets φ2mm
* Dimensions: 31*31mm (including the power pads)
The motors that I’m using are the Karearea TAO TOA 1507 LITE 4200KV 2-4S.
I tried it with both 4 and 8 kHz loop frequencies and lowered the ESC Motor protocol from 600DSHOT to 300DSHOT and no luck.
Not sure why this is happening. I’m a big of a loss. Any recommendations would be much appreciated.
Are you reading 100% after you plug in a battery or before?
Hi Tom,
You’re right on the money.
The 100% errors are only showing when I don’t have a battery plugged in. This threw me off because this is not the case with some of my other quads that I have RPM filtering working.
Many thanks for your quick and intuitive response/recommendation.
Stay safe and healthy.
Salik
