Charger
gcopter1
Since the Avata combos don't come with a charger, what are you guys intend to use?
I have an Anker charger for my iPhone 12, but that one only has one USB C port, looking for another that has multiple USB C ports to charge all the batteries for the Avata combo.
TIA
I use my laptop's or phone's 65W chargers.
The battery doesn't have an USB-C plug on it, so you won't be able to use multiple USB-C outputs to charge multiple of them without finding additional charger blocks (that are not sold separately besides the 4-battery charging hub).
From the specs a 45W charger that can supply either 15V/3A or 20V/2.25A profiles should give the max charge rate.
Also used several 45W capable powerbanks successfully.
@Kilrah what brand/model is that USB-C tester? I have a few older A/micro/C testers that are really flaky with PD, really cable sensitive, won't negotiate and connect through them more often than not.
That's going to charge slower than you could have... but it'll work.
buck
