Corrupted Config : osd_units = 25xxx
koklimabc
I'm newbie on betaflight and really need to ask help from you all expertised guide and help here.
I've upgraded JHEF7DUAL to "Betaflight version 1.1.1 (legacy)" in moment,
My problems here:
  1. Failed : Wired Video In to VIN of FC from Camera, and VIOUT of FC to Video port of VTX
    Success : Wired Camera Signal directly to Video Signal of VTX
  2. In CLI, When I'd typed out "diff all" to check out and ended out with an errors as "CORRUPTED CONFIG: osd_units" under set osd_units,
master​
set gyro_lowpass2_hz = 325
set dyn_notch_range = LOW
set dyn_notch_width_percent = 0
set dyn_notch_q = 200
set dyn_notch_min_hz = 90
set dyn_lpf_gyro_min_hz = 260
set dyn_lpf_gyro_max_hz = 650
set motor_pwm_protocol = DSHOT600
set yaw_motors_reversed = ON
set small_angle = 180
set pid_process_denom = 1
set osd_units =
###ERROR: CORRUPTED CONFIG: osd_units = 25###
set osd_rssi_alarm = 96
set osd_cap_alarm = 742
set osd_alt_alarm = 0
set osd_vbat_pos = 14360
set osd_rssi_pos = 14337
set osd_flymode_pos = 14842
set osd_gps_sats_pos = 14816
set osd_home_dir_pos = 14827
set osd_home_dist_pos = 14828
set osd_flight_dist_pos = 14821
set osd_altitude_pos = 14834
set debug_mode = SMARTAUDIO
set vtx_band = 5
set vtx_channel = 1
set vtx_power = 1
set vtx_freq = 5658
Kindly appreciate somebody could help me to fix up on this problem, Thanks a lot.
What would be helpful here is a summary of the items in play here. What is the FC? What version of Betaflight are you using? What exact firmware did you attempt to load? With this information, we should be able to get you back to a working state. You can also post pictures of the FC and a screenshot of your Betaflight.
Dear droneguy,
Tq for your reply. FYI, FC is JHEMCU F7 AIO Flight controller. I'm using latest version of betaflight and loaded with firmware 1.1.1 (legacy version)
I've finally solved this problem by setting "osd_units" to "Imperial" and then solder Camera Video in to FC board and VTX video to Video out on FC board. It worked fined already.
Tq for your concerned.
Glad to hear you are up and running!!
