Decrypt any DJI flight log with Flight Reader
A new version of Flight Reader is available. Release 1.8.11 includes the following changes:
  • Added Export Settings and Import Settings options to the File menu in the main Flight Reader window. These allow all configured settings to be exported to a file and later imported into Flight Reader from that saved file.
  • Improved mobile device location extraction to display the location of any DJI remote controller that contains a GPS receiver. This data is extracted into the APPGPS.latitude and APPGPS.longitude fields and is also displayed on the map with a blue "M" pin to mark the mobile device's current location.
  • Added a new field named OSD.yawDelta to track the absolute change in the aircraft's rotation (in degrees) between the current record and the previous record.
  • Added a new field named OSD.tiltInclinationDelta to track the absolute change in the aircraft's overall tilt angle (in degrees), calculated from the aircraft's roll and pitch angles, between the current record and the previous record.
  • Increased the precision of the OSD.tiltInclination field from 1 decimal place to 2 decimal places to allow for greater accuracy.
  • Rebuilt the photo extraction logic to improve the accuracy of detected photo locations and the total number of photos taken in the flight log.
  • Improved extraction of dual battery data when a second battery is recorded in the flight log.
See the release notes for a complete list of changes.
A new version of Flight Reader is available. Release 1.8.15 includes the following changes:
  • Upgraded from .NET 7 to .NET 10 to take advantage of the latest .NET performance improvements. .NET 10 is only compatible with Windows 10 or newer.
  • Improved the photo extraction logic to increase the accuracy of detected photo locations and the total number of photos taken in the flight log.
A new version of Flight Reader is available. Release 1.8.19 includes the following changes:
  • A new Flight Path Points setting is available in the KML section of the Flight Reader Options window that allows you to reduce the size of generated KML files by up to 95%. It does this by removing repeated flight path points that do not affect the overall shape of the flight path.
  • Flight Reader now extracts ADS-B data from DJI TXT flight logs for drones equipped with DJI AirSense. That includes all DJI drones over 249g starting with the Air 2S.
  • Airplane icons are now shown on the map to display the positions of all manned aircraft detected during the flight.
  • Right click any flight in the main Flight Reader window and select KMLADS-B KML to open Google Earth and view or play back the flight paths of all manned aircraft detected during the flight.
  • The following new log fields have been added to show details for the manned aircraft currently closest to the drone and details for the manned aircraft that had the closest separation distance during the flight:
    • ADSB.currentAircraft The number of manned aircraft detected by ADS-B at this point in the flight.
    • ADSB.totalAircraft The total number of unique manned aircraft detected by ADS-B so far in the flight.
    • ADSB.currentAltitude [ft] The current altitude (in feet) above mean sea level of the manned aircraft currently closest to the drone.
    • ADSB.currentAltitude [m] The current altitude (in meters) above mean sea level of the manned aircraft currently closest to the drone.
    • ADSB.currentHeading The current direction of travel (between 0 to 360 degrees) of the manned aircraft closest to the drone.
    • ADSB.currentHorizontalDistance [ft] The current horizontal ground distance (in feet) between the drone and the manned aircraft closest to the drone.
    • ADSB.currentHorizontalDistance [m] The current horizontal ground distance (in meters) between the drone and the manned aircraft closest to the drone.
    • ADSB.currentHorizontalDistance [mi] The current horizontal ground distance (in miles) between the drone and the manned aircraft closest to the drone.
    • ADSB.currentIcao The ICAO 24-bit hexadecimal identifier of the manned aircraft currently closest to the drone.
    • ADSB.currentLatitude The current latitude of the manned aircraft closest to the drone.
    • ADSB.currentLongitude The current longitude of the manned aircraft closest to the drone.
    • ADSB.currentSlantDistance [ft] The current true three-dimensional distance (in feet) between the drone and the manned aircraft closest to the drone.
    • ADSB.currentSlantDistance [m] The current true three-dimensional distance (in meters) between the drone and the manned aircraft closest to the drone.
    • ADSB.currentSlantDistance [mi] The current true three-dimensional distance (in miles) between the drone and the manned aircraft closest to the drone./li>
    • ADSB.currentSpeed [km/h] The current ground speed (in km/h) of the manned aircraft closest to the drone.
    • ADSB.currentSpeed [mph] The current ground speed (in mph) of the manned aircraft closest to the drone.
    • ADSB.currentSpeed [m/s] The current ground speed (in m/s) of the manned aircraft closest to the drone.
    • ADSB.currentVerticalDistance [ft] The current vertical separation (in feet) between the drone and the manned aircraft closest to the drone.
    • ADSB.currentVerticalDistance [m] The current vertical separation (in meters) between the drone and the manned aircraft closest to the drone.
    • ADSB.closestIcao The ICAO 24-bit hexadecimal identifier of the manned aircraft with the smallest true three-dimensional separation distance from the drone so far in the flight.
    • ADSB.closestSlantDistance [ft] The smallest true three-dimensional distance (in feet) between the drone and a manned aircraft (CPA) so far in the flight.
    • ADSB.closestSlantDistance [m] The smallest true three-dimensional distance (in meters) between the drone and a manned aircraft (CPA) so far in the flight.
    • ADSB.closestSlantDistance [mi] The smallest true three-dimensional distance (in miles) between the drone and a manned aircraft (CPA) so far in the flight.
      NOTE: If you don’t see the fields mentioned above, you can add them in the Log/Reports section of the Flight Reader Options window. The Options window can be accessed from the Flight Reader system tray icon or the File menu in the main Flight Reader window. Existing flight logs will then need to be reprocessed in order to regenerate the logs with the newly selected log fields.
A new version of Flight Reader is available. Release 1.8.21 includes the following changes:
  • Improved photo extraction logic to increase the accuracy of detected photo locations for flights that include videos and timelapse photos.
  • Clicking a manned aircraft icon on the map or in an ADS-B KML file will now open the adsbexchange.com link directly to the flight date, showing all aircraft flight paths for that day.
  • Removed the ADS-B speed fields introduced in version 1.8.19 since the speeds could not be derived consistently or accurately from the ADS-B data stored in DJI flight logs.
  • Improved ADS-B data extraction to ensure all available data points are captured. Extracted data is now also compacted to reduce the size of generated HTML and KML files.
  • When exporting all KML files (right-click flight list → Export → KML), the ADS-B KML file is now included when ADS-B data is available.
A new version of Flight Reader is available. Release 1.8.23 includes the following changes:
  • When Line Transparency or Ground Line Transparency is set to 100% in the KML section of the Flight Reader Options window, that line type will now be excluded from the generated KML file. This makes it easy to generate a KML that shows only the aerial flight path or only the ground-attached flight path. When both settings are below 100%, both lines will be included as expected.
  • Resolved an issue where invalid characters in ADS-B data could cause some flight logs to fail during processing.
A new version of Flight Reader is available. Release 1.8.25 includes the following changes:
  • When opening a CSV file, any brackets in the filename will be replaced with parentheses. This allows the file to be easily saved from Excel after making changes.
  • Improved photo extraction logic to increase the accuracy of detected photo locations for flights that include pano photos.
A new version of Flight Reader is available. Release 1.8.26 includes the following changes:
  • Improved photo extraction logic to increase the accuracy of detected photo locations for flights that include multi shot photos.
  • Updated the generation of the OpenStreetMap preview image that appears when hovering over flights in the main Flight Reader window to prevent “Access Blocked” messages.
A new version of Flight Reader is available. Release 1.8.27 includes the following changes:
  • Renamed the "Time Lapse" flight mode to "Timelapse".
  • Renamed the CAMERA.panoPhotoSequence field to CAMERA.photoSequence so it can be used to track photo sequences for other photo modes.
  • For timelapse photos, the CAMERA.photoSequence field now tracks the number of photos captured within each timelapse sequence.
  • Improved photo extraction logic to increase the accuracy of detected photo locations.
A new version of Flight Reader is available. Release 1.8.30 includes the following changes:
  • Added support for processing Avata 360 flight logs.
A new version of Flight Reader is available. Release 1.8.32 includes the following changes:
  • Added support for processing Lito X1 flight logs.
viktor.rybk
