Hi all, was going to post about my first 3 crashes, but removed it as no one wants to read about that.
I recently noticed that when my gimbal is set to 0 in normal mode and switch to manual mode, at 0 it is looking 15 degrees down, although the scale says it is set at 0.
In other words, in normal at 0 degrees, the gimbal points at the horizon. When i switch to manual and set the gimbal to 0, it points at about 15 degrees lower than the 0 in normal. If i set the gimbal to 15 degrees up in manual, then when i transition from normal (set at 0) to manual (set at 15 up), they now both point at the same place.
Calibrating the gimbal shows no problem, but there remains a 15 degrees difference between the 0 degrees setting in manual and normal mode.
Can anyone assist by explaining this?
