Drone issue with esc
Quintanschank
So I just built my 230 rooster frame drone with dshot 1200 esc’s, lux v2 fc, and crazepony 2300 kv motors. I had a problem connecting to the beta flight configuratior, but I installed new drivers and now it works perfectly. The issue I’m having is that blheli configuratior will say it’s conneced and try to start but says it can’t connect after like 10 seconds. Is there something I have to do download to get this to work because I need to flash my escs in order to finish programming the drone?
Are you using the correct configurator? There's one for BLHeli_S and one for BLHeli32
Reactions: rtkDarling
Also, make sure that you disconnect from beta flight or you won’t be able to talk to blheli
Reactions: RENOV8R
