Eachine ER8 2.4G Transmitter not binding to novice iii drone.
Llama
I recently purchased an Eachine novice iii and after only a few flights (about 4) the ER8 transmitter stopped connecting to the drone. I accidentally plugged in a low power LiPo battery but the battery and I know you're not supposed to do things like that but it was a brand new battery and had only been used once, Same with the transmitter. The strange part is I went into betaflight and rebinded the drone to the transmitter and it seems like the drone is connected to the transmitter but the transmitter isn't connecting to the drone. I have scoured the internet and have tried everything and I'm truly at a loss. I'm new to fpv drones so literally anything helps. Thanks.
Its a known issue that requires you to plug the quad into BetaFlight and use the CLI at the bottom to rebind. But at the same time it may have also wiped out all your settings.
karakai_07
