Flysky FS-i6S burned
darkin25
Hello I plugged batteries into my transmitter and it start smoking, I take it apart and I spot that one component is burned. Is it possible to repair it? Please help, Thank you
It is a capacitor, numbered c5. If you can find a picture of a good board, Google should find the specs from the capacitor's label. It is probably the same as the one numbered c6 in that first picture. You can order a replacement from digikey or somewhere like that. Be sure the reacement has same physical measurements as well.
So it looks like you need a 47uF 10V 10% cap, but I don't know what size you need. The one you linked seems pretty big. The size is given by a 4 digit code. Usually metric in 10ths of mm, so 3528 like those linked would measure 3.5mm by 2.8mm. Measure the good cap to see what size you need. Then you can find one on mouser.com or digikey.com.
Here is a search with everything except the size chosen (I hope link works).
Mouser Electronics
Texecdeza
