Flysky FS-i6S won't bind with fli14+ 1.7g receiver
Trailbrake
I bought the transmitter used. The previous owner added an external antenna at some point, but I opened the case and don't see any issues with that. The tx is set to i-bus and I can put the receiver in bind mode, but the 2 won't pair. Any thoughts?
Sorry, quick Google search says the i6s is AFHDS 2A and the fli14+ is as well. There shouldn't be any issues there.
If I remember correctly the i6s support both protocols, and you might have to select the right protocol in the transmitter. I dont have my i6s anymore, so I cant check the setup menu myself.
The problem turns out to be a bad rx. We tried another one that bound immediately. Thanks!
Reactions: Wrecked and Wayno52
Harold_31
