Help, my drone keeps going full throttle
Dutch
I am still fairly new to fpv. I have a mobula8 with avatar. After some crashes recently I tried to fly it and as soon as I would take off it skyrockets straight up. I tried changing the propellers and the frame and still the same problem. Today I just changed out the aio flight board thinking maybe it had a gryo out or something. Took it out flying today and ran pack through it just fine. I stayed in angle mode just for the test flight. Next pack it is back to full throttle after takeoff. I tried acro and angle mode, same problem. Any ides?
I might try calibrating the gimbals on my radio. Doesn't quite sound like a problem with the Mobula8
BTW may I ask where you got the new flight controller. I've not been able to find one.
Thanks
I ordered it off aliexpress. Took a couple weeks but no problems with the seller or shipping. I don't think it's the radio because I am currently out flying my Rate L40 and it doesn't have any problems, other than the pilot.
I wonder if one of the motors is out of whack. How would one check those?
I'm also considering just getting a new beta pavo II and moving the vtx over.
Thanks I'll try aliexpress.
I check motors with the BetaFlight configurator Motors tab by running each of them up one at a time. I wouldn't suspect just one motor because if they weren't all four throttling up at the same time, the quad would flip over rather that fly up.
I have also reflashed beta flight and the factory cli to make sure it wasn't something I changed.
I'm stuck at this point and kinda wish I hadn't ordered the new board.
buck
