Help with happymodel larva x2
Twh
I am new to Fpv and sociology…. Just bought used happymodel larva x2… it has three wires to wire in receiver…. Will that work with expresslrs
Hey Twh,
That setup can definitely work with ExpressLRS. Most ELRS receivers only need three wires: 5V, GND, and TX. Just make sure the flight controller on your Larva X2 has a spare UART RX pad, and enable Serial RX for that UART in the Betaflight Ports tab.
In the Configuration tab, set:
  • Receiver mode: Serial-based receiver (e.g., SBUS, CRSF)
  • Protocol: CRSF (that’s what ExpressLRS uses)
After that, you should be good to go.
If you get stuck, you’ll find a lot of detailed guides and videos out there. There is a lot of helpful info and great video on plenty of websites.
Joshua Bardwell has a great YouTube channel for visual learners, and Oscar Liang’s site is full of solid technical explanations.
bullbloke
