Speedbee F405AIO cannot detect Baro and MAG
Ekaterina
Canada
Hi, I recently bought Speedy Bee F405 AIO, and soldered wires, and my 4inch drone's all basic functions are fine, but I have 2 troubles.
1 Barometer is not detected. this chip should have the baro. Is this an initial failure product, probably?
2 GPS is working but Mag is not detected from a GEPRC's GEP-M10Q which has GPS and MAG. (Wire soldering should be correct.)
And Actually this is second time to purchase the chip, and my 3inch drone is using the same Speedbee F405AIO and Baro is working but MAG is not working, too. I tried to flash fireware with Mag option for sure.
I attached 2 Betaflight's screen capture pictures, so I appeciate if you could share any thought, or had same problems and solved.Speedbee F405AIO Issue 01.jpg
WilliamDaugherty
