Help with Rates
Obsidian Triniti
Hello everyone,
I am still learning how to tune (I'm VERY green). I've gone thru some YouTube vids and still seem to be having no luck. I have a Sector5 v3 (HGLRC) - 4S - with 2306/2550kv motors. I do some freestyle mixed in with a little cinematic. The issue started when I changed from a GoPro Hero 8 to a SMO 4k. There is a lot of bounce back on the roll axis, of course only when making aggressive moves. This told me that I needed to increase D on the roll axis. I've been adjusting the D Max (not sure if this is correct . . .) - I'm still getting the issue . . . so I'm posting here with the hopes that someone can let me know if I'm on the right track and what else I might be able to adjust to stock the bounce back on the roll axis. My rates, etc are attached. Thanks!
Any guidance you can provide would be greatly appreciated.
Regards
Hello, i am getting the same issue with the same setup.
Did you manage to sort this out ? If yes, can you please share the resolution ? :)
thanks
gopi
