Hello guys,
I'm trying to enable hidden features inside the app.
I successfully enabled developer tools and debug mode.
When I connect my FPV drone, nothing more than : Firmware, Log Exports and Calibration.
But, I've made a few research inside code. I finally inspected a javascript file named "wm170.js" and I found very interesting things, here's an extract :
It looks like it communicates with a Web Socket or something else ...
If you want to check the whole script, you can click here (and click on Javascript tab)
My knowledge ends here .. that's why I'm looking for someone to help me to enable hidden features !
Cheers,
Sleek
dashboard: { "zh-cn": "概览", en: "Dashboard", jp: "ダッシュボード", it: "Dashboard", de: "Cockpit", es: "Tablero", fr: "Tableau de bord", nl: "Dashboard", pt: "Painel de instrumentos", ru: "Приборная панель" },
basicsetup: { "zh-cn": "基本设置", en: "Basic Settings", jp: "基本設定", ko: "기본 설정" },
fcsetup: {
description: "//Flight Settings",
"zh-cn": "飞行设置",
en: "Flight Settings",
jp: "フライト設定",
it: "Impostazioni di volo",
de: "Flugeinstellungen",
es: "Ajustes de vuelo",
fr: "Paramètres de vol",
nl: "Vluchtinstellingen",
pt: "Definições de voo",
ru: "Летные настройки",
Pitch: { "zh-cn": "俯仰", en: "Pitch", jp: "ピッチ", it: "Beccheggio", de: "Nicken", es: "Cabeceo", fr: "Angle vertical", nl: "Hellen", pt: "Passo", ru: "Тангаж" },
Roll: { "zh-cn": "横滚", en: "Roll", jp: "ロール", it: "Rollio", de: "Rollen", es: "Alabeo", fr: "Roulis", nl: "Rollen", pt: "Rotação", ru: "Крен" },
Yaw: { "zh-cn": "航向", en: "Yaw", jp: "ヨー", it: "Imbardata", de: "Gieren", es: "Guiñada", fr: "Lacet", nl: "Gieren", pt: "Guinada", ru: "Рыскание" },
Pan: { "zh-cn": "平移", en: "Pan", jp: "パン", it: "Rotazione orizzontale (pan)", de: "Horizontaler Schwenk", es: "Giro", fr: "Angle horizontal", nl: "Pannen", pt: "Oscilação", ru: "Поворот" },
Thru: { "zh-cn": "油门", en: "Throttle", jp: "スロットル", it: "Acceleratore", de: "Gas", es: "Acelerador", fr: "Manette des gaz", nl: "Gashendel", pt: "Acelerador", ru: "Тяга" },
CraftInfo: { "zh-cn": "飞行器信息", en: "Aircraft Information", jp: "機体情報", ko: "항공기 정보" },
ESCType: { "zh-cn": "类型", en: "Type", jp: "タイプ", ko: "종류" },
DJIESC: { "zh-cn": "DJI 智能电调", en: "DJI Intelligent ESC", jp: "DJI スマート ESC", ko: "DJI 인텔리전트 ESC" },
OtherESC: { "zh-cn": "其他电调", en: "Other ESC", jp: "その他のESC", ko: "그 외 ESC" },
Gear: { "zh-cn": "起落架", en: "Landing Gear", jp: "ギア", it: "Carrello di atterraggio", de: "Landegestell", es: "Tren de aterrizaje", fr: "Train d'atterrissage", nl: "Landingsgestel", pt: "Trem de aterragem", ru: "Шасси" },
up: { "zh-cn": "收起", en: "Up", jp: "上", it: "In alto", de: "Hoch", es: "Arriba", fr: "Haut", nl: "Omhoog", pt: "Para cima", ru: "Вверх" },
down: { "zh-cn": "放下", en: "Down", jp: "下", it: "In basso", de: "Herunter", es: "Abajo", fr: "Bas", nl: "Omlaag", pt: "Para baixo", ru: "Вниз" },
RCType: { "zh-cn": "类型", en: "Type", jp: "タイプ", ko: "종류" },
VPS: { "zh-cn": "VPS", en: "VPS", jp: "VPS", it: "VPS", de: "VPS", es: "VPS", fr: "VPS", nl: "VPS", pt: "Sist. posicionamento visual", ru: "VPS" },
AircraftType: {
"zh-cn": "机架类型",
en: "Airframe Type",
jp: "機体タイプ",
it: "Tipo di velivolo",
de: "Flugrahmentyp",
es: "Tipo de estructura de aeronave",
fr: "Type de cellule",
nl: "Cascotype",
pt: "Tipo de célula",
ru: "Тип корпуса летательного аппарата",
Cheers,
Sleek
