How to assign Flight Modes to a switch on a Spectrum DX6 with Vortex pro 250?
doberman
Pembroke Pines, FL
Hello all,
I am getting frustrated with such simple tasks. I cant figure out how to assign a 3 way switch to flight modes. Google'd, youtube'd, read the manuals. No luck.
Can someone please help me set this up point me in the right direction? This should not be this hard.
Thanks
Connect to Cleanflight/Betaflight
1. With receiver powered, go to Receiver tab and toggle the switch you want to use. Note what channel moves on the bar graph.
2. Go to modes tab, click "add range" on desired mode and select the noted channel.
3. Set switch to desired position for the mode, and place the sliders on either side of the switch indicator line.
4. CLICK SAVE. Test to see if mode icon lights up when switch is in desired position.
5. You can set another mode to a different position on the same switch by repeating the above for the other mode.
Darmie
