I want to swap my Camera but......?
Serius
My stock camera is not bad but soon I would like to swap it for higher resolution & CCD (I have Cmos now). My issue is that the stock camera wires run to a small white connector attached to the PDB & the aftermarket camera wires run to a larger black connector.
You're going to have to desolder the plug fro the board or cut the plug from your current camera and use for your new one.
Serius,
Yeah, I just replaced a camera in my P200 yesterday and had the same issue to deal with. I had to de-solder and solder the new (+) and (-) wires on the PDB. My old camera was wired inside the camera body and the new one had an external 3 pin connector (+,-, Signal) so the 3 wires going to the VTX connector from the camera had to be cut, spliced and soldered. I'm not used to working with such small wires and connectors but was able to get it done.
Ohhh, ok. Thanks guys
