I'm in the US, but I think I'm in CE mode as my range is pretty bad and if I go to Transmission settings and change to Manual Mode, I'm only seeing 1 Channel on 40mhz. From what I've seen there are supposed to be 3 channels.
1/2 mile at that height is not good at all. Not sure why no one can say how to tell if you are in FCC mode or CE. Both my friend and I both live in the US and only have 1 Channel when set Transmission to Manual. I had to use the Hack to get 3 channels.I finally remembered to test this. Avata with Motion controller and DJI Goggles 2. Clear, Texas day. 87º. I flew between 300 and 400 ft up and I got just over a half mile 2640 ft. before the video started to glitch out. That seems decent to me.
What is a bit worrisome is I can't go "dive bombing" -- flying in and out of trees, etc -- except when the drone is relatively close. I'd guess about 500 ft before it gets a flaky. I can generally recover and get a good signal back without wrecking but it seems iffy at times.
What hack are you talking about? (I'll also surf around and see if I can find it.). Do you have any distance measurements either before or after the hack?1/2 mile at that height is not good at all. Not sure why no one can say how to tell if you are in FCC mode or CE. Both my friend and I both live in the US and only have 1 Channel when set Transmission to Manual. I had to use the Hack to get 3 channels.
