Issues Installing New ELRS Reciever
NyxOTNX
Hello everyone,
I am newer to the world of FPV and have recently purchased my first non-commercial FPV drone, a Venom H20 HD from Flywoo. Now for various reasons I ended up with a version that did not ship with a reciever (I had a deal for a v1 DJI controller but it fell through) and have decided to add my own ELRS reciever, so I purchased a Radiomaster RP1 and a matching Zorro TX, which I am very happy with.
I have sucessfully soldered the reciever to the existing reciever wiring on the drone (I had it checked by an actual avionics specialist) and the reciever works. I've flashed the latest ELRS firmware onto both the TX and the RX and installed the necessary .lua scripts on the TX as well, and they pair up right away with eachother. The problem is the TX is not being recognized by the drone in Betaflight, so I'm going to assume that the RX and the FC are not communicating with eachother properly. The FC is a Goku Hex F411 and as such I checked the box in the ELRS configurator to invert the CRSF signal to allow it to communicate with the SBUS only FC, and also verified that the UART which is set to serial in BetaFlight matches the physical one on the FC.
The problem I'm having is that I don't know if Flywoo did anything during the setup of this drone (because even though they ship a version with a CRSF reciever, this one was intended to use the built in DJI reciever in the Caddx Vista) that's causing me a problem, and since I don't yet know what exactly I don't know, I can't even Google an answer. If anyone has some insight I would be very greatful.
Did you actually change the receiver type to CRSF in BF?
As Kilrah says you have to set the Betaflight and the Radiomster Zorro 4 in 1 module to CRSF. The ELRS works off the CRFR protocol.
WilliamDaugherty
