Jumper T16 not Connecting to TBS Crossfire Micro TX V2
This issue has be reported by a small group of people. It appears that the pin alignment is off on some units and therefore do not properly connect to the TX module in the JR bay. You can take a look at the pins in the JR bay and make sure they are perfectly perpendicular to the back. A slight bend upwards can result in the pins connecting in the wrong holes in the TX module (with the top pin going over the last hole).
This is likely your issue. Take a picture of your JR bay and I can likely confirm this for you.
Thank you for the advice. I’ll check again, but I don’t think this is the case with mine.
If it is, I will report back.
It's very subtle so take your time and check very carefully.
I think I just had the same problem. Flashed everything, TX16s and the crossfire module. The module was getting power but it wasn't being detected. Turns out I had to go into Model Setup then turn the Internal RF to OFF. Then I ran the crossfire lua script and it worked.
Specter72
