Mw settings on hv tramp?
baevans11
I am kinda confused in this area of what power settings to use on this thx. What do the different power output setting do? Sorry if this a stupid question im just trying to learn. Thx.
The higher wattage out, the better reception but also more drain on battery. Also, if you are flying with someone, higher wattage bleeds over onto thier channel
Reactions: baevans11
Ok thx so somewhere in the middle would be best if I'm flying solo? Decent reception without too much drain on the battery?
Yes, i use 600mw most of the time. Usually at races the max is 200mw tho. You will be able to tell the difference in lipo life between the two
