Need help please
CNK9890
I recently purchased an eachine wizard x220 and I have gone on beta flight and done what people have said on YouTube to set it up the only problem is that it doesn't fly and won't arm at all any suggestions
It's not showing at all but I know my controller is bound to the reciever because the led isn't blinking
Make sure your receiver type is set right in cleanflight (serial receiver, s.bus?) and that on ports tab you have the right port set up for serial receiver, assuming you are using a serial receiver (like s.bus or ppm). If that is all good, check the wiring from receiver to flight controller.
Like he said chi all ur ppm or subs in beta flight also make sure radio is on same as board like Tare or Taer then go to modes add range on radio switch and set up and configure
RFPV
